Block Url
I have Pix 515E i have a specfic url that i want to block. I relaize i can instal a server like websense or the like but i feel that is overkill to just block this 1 url. Is there a rule i can add in to the pix to not allow to go to that site? I don't care if the ie error comes up or it redirects somewhere else. Please advise Thank you
Collin Clark Mon, 02/05/2007 - 06:41
In your internet router, you can send the IP to null0. That would block the IP, not just the URL.
HTH and please rate.
Collin Clark Mon, 02/05/2007 - 07:05
A couple of choices then. You could route that specific IP to somewhere else (not suggested) or create a more specific Deny statement in your ACL blocking port(s) to the IP.
HTH and please rate
