sit-to-site VPN with pppoe connection
Feb 5th, 2007
We have 2 pixes (a 515 and a 506e) doing a vpn between the 2. The tunnel is up but the 506e side can not connect to anything. I do see the tunnel between the two is up.
config of the 515 pix:
access-list 100 permit icmp any any echo-reply
access-list 100 permit icmp any any time-exceeded
access-list 100 permit icmp any any unreachable
access-list 101 permit ip 172.16.10.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list 101 permit ip 172.16.10.0 255.255.255.0 11.1.1.0 255.255.255.0
interface ethernet0 auto
interface ethernet1 auto
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x 255.255.255.248
ip address inside 172.16.10.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnpool 11.1.1.1-11.1.1.254
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group 100 in interface outside
route outside 0.0.0.0 0.0.0.0 y.y.y.y 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
url-cache src_dst 128KB
http server enable
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 1 set transform-set myset
crypto map mymap 1 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
isakmp enable outside
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
vpngroup vpn3000 address-pool vpnpool
vpngroup vpn3000 dns-server platt_dc
vpngroup vpn3000 default-domain company.com
vpngroup vpn3000 idle-time 1800
vpngroup vpn3000 password ********
vpngroup vpngroup idle-time 1800
ssh Cisco 255.255.255.255 outside
ssh timeout 5
terminal width 80
Config on pix 506e:
PIX Version 6.2(2)
access-list 101 permit tcp 192.168.0.0 255.255.255.0 172.16.10.0 255.255.255.0
pager lines 24
logging on
logging console debugging
logging monitor debugging
logging buffered debugging
mtu outside 1500
mtu inside 1500
ip address outside pppoe setroute
ip address inside 192.168.0.1 255.255.255.0
pdm logging warnings 100
pdm history enable
arp timeout 14400
http server enable
http 192.168.0.1 255.255.255.255 inside
http 192.168.0.51 255.255.255.255 inside
http 192.168.0.0 255.255.255.0 inside
telnet x.x.x.x 255.255.255.255 outside
telnet 172.16.10.0 255.255.255.0 outside
telnet 192.168.0.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
vpdn group pppoegroup request dialout pppoe
vpdn group pppoegroup localname [email protected]
vpdn group pppoegroup ppp authentication pap
vpdn username [email protected] password ********
dhcpd address 192.168.0.50-192.168.0.100 inside
dhcpd dns 198.235.216.134 172.16.10.2
dhcpd lease 504000
dhcpd ping_timeout 750
dhcpd domain company.com
dhcpd enable inside
vpnclient vpngroup vpn3000 password ********
vpnclient server x.x.x.x
vpnclient mode network-extension-mode
vpnclient enable
terminal width 80
ggilbert Mon, 02/05/2007 - 13:42
Can you send me the output of "sh cry ipsec sa" from the PIX 506 and PIX 515 side, please.
gilbert
slashman26 Mon, 02/05/2007 - 13:50
from the 515:
interface: outside
Crypto map tag: mymap, local addr. x.x.x.x
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
remote ident (addr/mask/prot/port): (192.168.0.0/255.255.255.0/0/0)
current_peer: y.y.y.y
dynamic allocated peer ip: 0.0.0.0
PERMIT, flags={}
#pkts encaps: 578894, #pkts encrypt: 578894, #pkts digest 578894
#pkts decaps: 510403, #pkts decrypt: 510403, #pkts verify 510403
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: x.x.x.x, remote crypto endpt.: y.y.y.y
path mtu 1500, ipsec overhead 56, media mtu 1500
current outbound spi: 6cb5050f
inbound esp sas:
spi: 0xc3e68cb8(3286666424)
transform: esp-3des esp-md5-hmac ,
slot: 0, conn id: 4, crypto map: mymap
sa timing: remaining key lifetime (k/sec): (4554513/4548)
IV size: 8 bytes
replay detection support: Y
inbound ah sas:
inbound pcp sas:
outbound esp sas:
spi: 0x6cb5050f(1823802639)
in use settings ={Tunnel, }
slot: 0, conn id: 3, crypto map: mymap
sa timing: remaining key lifetime (k/sec): (4427269/4518)
IV size: 8 bytes
outbound ah sas:
outbound pcp sas:
remote ident (addr/mask/prot/port): (y.y.y.y/255.255.255.255/0/0)
PERMIT, flags={}
#pkts encaps: 755, #pkts encrypt: 755, #pkts digest 755
#pkts decaps: 1031, #pkts decrypt: 1031, #pkts verify 1031
current outbound spi: 72df43d3
inbound esp sas:
spi: 0xf2df4b77(4074720119)
slot: 0, conn id: 2, crypto map: mymap
sa timing: remaining key lifetime (k/sec): (4607906/3246)
IV size: 8 bytes
inbound ah sas:
inbound pcp sas:
outbound esp sas:
spi: 0x72df43d3(1927234515)
slot: 0, conn id: 1, crypto map: mymap
sa timing: remaining key lifetime (k/sec): (4607969/3237)
IV size: 8 bytes
outbound ah sas:
outbound pcp sas:
ggilbert Mon, 02/05/2007 - 14:07
According to this output, it seems like the packets are getting encrypted and decrypted.
PERMIT, flags={}
Can you explain to me what you meant by the term "connected" in your original problem description.
Are you able to ping from the client side to the remote network (PC to PC).?
gilbert
slashman26 Tue, 02/06/2007 - 05:24
doing a sh cry isakmp sa shows a dst IP and src IP; state of QM_IDLE and created of 2 on both sides. Pinging from either pix to outside interface of the other pix works. Ping inside interface of one pix from other pix does not work. The 506e is a PPPOE dsl connection so its public IP is always changing. (we have a static and more bandwidth on order just waiting for the confirmation on it).
