I am trying to configure my CME for site to site outbound calls...
Feb 5th, 2007
I keep getting error msg "sorry you call didn't go through" when trying to make outbound calls from site to site with 10 digit dialing throught the PSTN....PRI connected..Controllers up....I can make extension to extension calls
Brandon Buffin Mon, 02/05/2007 - 13:49
Can you make other inbound/outbound calls at these sites, just not between the sites? Can you post your configs?
Brandon
dgahm Mon, 02/05/2007 - 17:13
Here is a problem with the Newport config. The forward digits 0 says send out no digits. If you remove that everything after the 8 will be sent, which is probably what you want.
dial-peer voice 3 pots
destination-pattern 8T
incoming called-number .
port 0/2/0:0
forward-digits 0
To see what is actually being sent use debug vpm signal and place a call.
Please rate helpful posts.
gracianogardunojr Wed, 02/07/2007 - 14:24
Try this dial-peer.
dial-peer voice 42 pots
description National calls
destination-pattern 81[2-9]..[2-9]......
port 0/2/0:0
forward-digits 11
