Cisco 7206 non-VXR with NPE-150
Feb 5th, 2007
I got an old 7206 non-VXR with NPE-150. I tried different IOS versions (mostly 12.2.x), but none seems to work. I always get invalid opcodes. So what's the latest version that should work on the 7206 non-VXR with NPE-150 and supports the following features:
- BGP
- NHRP
- VPDNS (L2TP/PPTP)
- IPv6
Thank you,
Martin
Richard Burts Mon, 02/05/2007 - 13:17
Martin
I checked in the Software Advisor in CCO and it indicates that for 7206nonVXR the latest version supported is 11.2(1).
Rick
martinkluge Mon, 02/05/2007 - 13:52
Hi Rick
thank you for your answer. 11.2(1) is really old. I'm now running 12.2.40 which seems to work (also no IPv6 support).
Thank you,
Martin
sundar.palaniappan Mon, 02/05/2007 - 13:53
Rick,
It appears NPE-150 can run 12.2 code and in fact, 12.2(13)(c7200-is-mz.122-13.ZD2) seems to support all 4 functions Martin wants to enable on the 7206 w/NPE-150.
Martin, can you try that image and let us know if that helps.
Sundar
martinkluge Mon, 02/05/2007 - 13:59
Hi Sundar,
that are great news, the only problem is that this version doesn't exist on the cisco ftp server:
ftp> ls /cisco/ios/12.2/12.2.13-ZD3/7200
227 Entering Passive Mode (198,133,219,27,203,126)
150 Opening ASCII mode data connection for file list
226 Transfer complete.
ftp>
I also tried ZD1, ZD2 and others, no luck :)
Martin
sundar.palaniappan Mon, 02/05/2007 - 14:27
Rick,
Sorry, I should have been more specific where I got the info from. I was using software advisor tool as well to get the info.
Martin, unfortunately CCO shows 12.2 ZD as deferred image and isn't available for download as such. That seems to be the latest image available for your hardware configuration. The next one that comes up is c7200-is-mz.12.1-26.E8 but this one doesn't support ipv6 but does support the other 3 features you need.
If you want to get a definite answer then you may have to open a TAC case.
Good luck!!
Sundar
martinkluge Mon, 02/05/2007 - 14:31
Hi Sundar,
thank you for your help. I will keep on searching :)
Martin
Richard Burts Mon, 02/05/2007 - 13:59
Sundar
I do not have a non-VXR 7206 to check with and only report what the software advisor on CCO came up with. If there is code that is newer that will work, then Cisco should update the tool.
Rick
