CME B-ACD Question
Feb 5th, 2007
I am trying to use the default script. However, I have only one queue. I just need B-ACD to run the welcome greeting and then ask the user to dial the extension. I don't want the B-ACD to pass the user to different queues.
Do I have to modify the TCL script or there is a way?
Thanks in advanced
Paolo Bevilacqua Mon, 02/05/2007 - 14:45
The problem is that even with one option only, the script will need one digit as selection before collecting the extension. So unless you are happy with something like "Press 1 followed by the extension desired", you will need a modified script.
m-haddad Mon, 02/05/2007 - 14:46
Is there is an easy way to modify the script. Because I opened the script using a text editor and it is pretty hard to modify!
Paolo Bevilacqua Mon, 02/05/2007 - 15:01
Indeed hacking IVR TCL may be not be hard, but not even a trivial task. I plan to do a little bit of work on that later on, and will come back to this thread when I have news.
Paolo Bevilacqua Thu, 02/08/2007 - 04:41
I hadn't the time to try this yet, but have you tried drop-through mode to the menu entry for dial by extension ?
