CCME FXO Call Waiting Hookflash
Feb 5th, 2007
I have configured CCME 4 on a 2811. I am using a vic2-4fxo connected to the PSTN on the first 2 FXO ports. The ports are configured as follows:
voice-port 0/0/0
supervisory disconnect dualtone mid-call
timeouts call-disconnect 5
timeouts wait-release 5
timing hookflash-out 50
connection plar xxxxxxx
description xxx-xxx-xxxx
caller-id enable
voice-port 0/0/1
caller-id enable
I have also configured the FXO-Hookflash in my telephony-system setup parameters.
telephony-service
fxo hook-flash
In CCME 4.x call waiting is enabled by default. I have the "flash" softkey present on all phones during a call. When a second call comes in, I am presented with the call waiting "beep." However, when I press the "flash" softkey, the hookflash is essentially ignored and the call never flashes to the call-waiting.
Ideas, Suggestions?
Thanks in advance.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 02/05/2007 - 15:42
50 msec hookflash sounds kind of short. Perhaps something like 150 or 200 should work. Also look at "debug vpm signal" to make sure sure hookflash is generated on key press.
lefty Mon, 02/05/2007 - 16:40
Thanks. Sometimes the obvious will get ya.
I increased the timing hookflash-out to 200 and the Call-Waiting works flawlessly now(anything below 200ms did not).
Thanks Paolo.
