CE network module
Feb 5th, 2007
Hi all,
Need your help to troubleshoot the problem when configuring Content Engine Network Module. This is my first experience configuring the CE. I am using ISR 2821, IOS version 12.4 and ACNS version 5.5.3.
The environment is a college university. There have three (3) campuses. The ISR and the CE network module are behind the firewall and using static NAT configured in the firewall to go to the Internet. The policies for the static NAT is only allowed http and https. Each site is configured using the same concept.
The service running on the CE network module is only standard web cache and redirection on port 80 only. The WCCP version enable is version 2.
I do not have a problem when configured CE network module on College A and look that the CE is working properly. They have student, admin and IT vlan. Only the student vlan is using proxy server to access the Internet. Until now the CE is running and I do not receive a complaint from them.
When I am configuring the same CE network module on College B, for the first 10 minutes it is working properly. Suddenly, the access to the Internet becomes intermittent. All the student, admin and IT vlan cannot access the Internet. After 5-10 minutes the line is back to normal and it always repeating. College B environment is little bit different because they have another routers in between.
College A : User > Access switch > ISR 2821 + CE > Firewall > Internet
College B : User > Access switch > Router > Router > ISR 2821 > Firewall > Internet
College A
version 12.4
service timestamps log datetime msec localtime show-timezone
hostname ABC
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip wccp web-cache
ip cef
ip name-server 192.9.201.1
interface GigabitEthernet0/0
description P2P Connection to DEF
ip address 192.168.111.1 255.255.255.240
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/0
description Connection to ABCswitch
switchport mode trunk
interface FastEthernet0/0/1
description Connection to P2P
switchport access vlan 14
interface FastEthernet0/0/2
description Conncetion to FIREWALL
switchport access vlan 4
interface FastEthernet0/0/3
interface Content-Engine1/0
ip address 192.9.111.1 255.255.255.0
service-module ip address 192.9.111.2 255.255.255.0
service-module ip default-gateway 192.9.111.1
interface Vlan1
ip address 192.9.100.15 255.255.255.0
interface Vlan4
description Connection to FIREWALL
ip address 192.9.192.10 255.255.255.0
ip wccp web-cache redirect out
router ospf 1
log-adjacency-changes
network 192.9.100.0 0.0.0.255 area 0
network 192.9.102.0 0.0.0.255 area 0
network 192.9.200.0 0.0.0.255 area 0
network 192.9.201.0 0.0.0.255 area 0
network 192.168.111.1 0.0.0.0 area 0
default-information originate always
no ip classless
ip route 0.0.0.0 0.0.0.0 192.9.192.11
ip http server
no ip http secure-server
CE network module
! ACNS version 5.5.3
hostname ContentEngineABC
http cache-cookies
http proxy incoming 80
http tcp-keepalive enable
ip domain-name abc.edu.com
interface FastEthernet external
shutdown
exit
interface FastEthernet internal
exit
no auto-register enable
wccp router-list 1 192.9.111.1
wccp web-cache router-list-num 1
wccp version 2
username abc password xxx
username abc privilege 15
authentication login local enable primary
authentication configuration local enable primary
! End of ACNS configuration
