Oops, wrong image.
Answered Question
Feb 5th, 2007
I accidentally loaded a wrong image into a SOHO 91.
How do I recover?
In many other routers there's a pre-boot environment where you can do this, but I haven't found it yet in the SOHO91.
Correct Answer by jain.nitin about 9 years 7 months ago
Hi, Below is the procedure to get into the rommon mode on SOHO 90 series routers
If break is enabled, go to Step 2. If break is disabled, turn the router off, wait 5 seconds, and turn it on again. Within 60 seconds, press the Break key. The terminal displays the ROM monitor prompt.
Step 2 Press break. The terminal displays the following prompt
rommon 2>
I hhope it will help u.
Thnx
Ninja
Overall Rating: 3 (1 ratings)
Frank Hoeben Fri, 02/09/2007 - 02:02
The problem is, I can't get into rommon in the first place.
Maybe the SOHO91 doesn't have a rommon?
If I could get there, uploading a different image via TFTP would be easy.
ahmednaas Sat, 02/10/2007 - 06:17
The SOHO 90 series certaily has a ROMmon. Unless you changed your config register, you should be able to get into rommon mode by sending a break key (ctrl-break) during the reboot.
Can you describe what you did to get in rommon mode?
Correct Answer
jain.nitin Sun, 02/11/2007 - 10:36
rommon 2>
Thnx
Ninja
Frank Hoeben Wed, 02/14/2007 - 05:19
Thanks for confirming the existence of rommon in the SOHO91. This made me look a little further.
In the end the solution is always so simple...
In Teraterm the break signal isn't send with ctrl+break, or any other combination with the break key, but with ALT+B *doh!*.
Waiting for xmodem to finish right now.
glen.grant Wed, 02/14/2007 - 05:59
ALT B or simply a dropdown from the top of the tera term window .
