Bgp policy
Answered Question
Feb 6th, 2007
Any one can help to resolve my confusion in bgp ..we have purchase AS number from APNIC . what kind of policy both outgoing and incoming that I have to in my BGP . I do have 2 ISP CONNECTIVITY. Is there any seperate configuration is needed?
thank u in advance
Correct Answer by royalblues about 9 years 7 months ago
Sample configuration attached
router bgp
network
neighbor remote-as
neighbor ebgp-multihop 4
neighbor remove-private-AS
neighbor route-map ISP1-acceptroutes in
neighbor route-map ISP1-local-routes out
neighbor remote-as 17495
neighbor description "Reliance BGP Peer"
neighbor ebgp-multihop 2
neighbor route-map ISP2-acceptroutes in
neighbor route-map ISP2-local-routes out
ip route
access-list 1 permit
access-list 3 permit 0.0.0.0
route-map ISP1-acceptroutes permit 10
match ip address 3
set local-preference 300
route-map ISP2-acceptroutes permit 20
match ip address 3
set local-preference 100
route-map ISP1-local-routes permit 10
match ip address 1
route-map ISP2-local-routes permit 10
match ip address 1
HTh, rate if it does
Narayan
Overall Rating: 5 (3 ratings)
John Patrick Lopez Tue, 02/06/2007 - 01:50
Where are you going to terminate both ISP? Is it a seperate router or the same?
For simplicity, just ask your ISP to advertise default routes to your router. Of course you need to create an eBGP peer to your ISP. Then create an iBGP from your internet router to one of your internal router. Advertise the default route to your iBGP peer router by using default-information-originate under BGP configuration.
Redistribute BGP into IGP into your internal router.
Correct Answer
royalblues Tue, 02/06/2007 - 08:13
router bgp
network
neighbor remote-as
ip route
match ip address 3
match ip address 3
match ip address 1
match ip address 1
Narayan
