Critical Help!
Overall Rating: 5 (4 ratings)
abhishek_nandavat Tue, 02/06/2007 - 03:03
Why dont you do this to disable the ports-
conf t
int range fa0/1 - 24
shut
and then after the required time, do this-
conf t
int range fa0/1 -24
no shut
This should get you through.
Hope this helps.
AbhisheK
Please rate all helpful posts!!!
sachinraja Tue, 02/06/2007 - 03:15
Hello Sayed,
I'm really not sure if there are such scripts on switches... anyway, you can use ciscoworks -> netconfig module to configure to enable or disable switchports, by predefining the commands on the server and scheduling it.. By doing this, the ciscoworks server can log onto "n" number of devices and automatically change the configurations.. i think this is the only/best option...
Hope this helps.. all the best.. rate replies if found useful..
Raj
sachinraja Tue, 02/06/2007 - 03:33
Yes Sayed... On the ciscoworks server, you can apply say the following commands:
interface range faste 1/0/1 - 48
shutdown
and program it for 1:00 AM to trigger it on NETCONFIG and include the switch IP addresses for which these rules will apply...
then u create another rule,
no shutdown
on the NETCONFIG and do a no shutdown..
Refer to this URL:
http://cisco.com/en/US/products/sw/cscowork/ps2073/products_user_guide_chapter09186a0080357772.html
or else , get hold of some software guys, who can write shell scripts, to automatically do telnet and change the configs ;)
Raj
