Sharing VLAN's on ACE context's
Answered Question
Feb 6th, 2007
I am quite a newbie with ACE configurations. I have a VLAN i want to share over three ACE context's. Every context needs to have its own vlan ip address. How can i manage to do this ? I can only define an ip address on the main ACE configuration.
Sebastian
Correct Answer by Roble Mumin about 9 years 7 months ago
you have to change into each context.
changeto BACKEND
conf t
interface vlan 40
ip address xyz
But i e.g. use one context for both. One serverfarm is in context a including the "front" and the "backside" and another serverfarm is in context b.
Overall Rating: 5 (1 ratings)
Roble Mumin Tue, 02/06/2007 - 03:12
You are probably talking about the transfer-network or client-side VLAN.
If you have already assigned the vlan to the module from the cat6k just create the three contexts and assigned those vlans to each context. That is how i do it. Serve three different context's with three different server networks with one client-side or transfer-network.
just make sure you use different ip's for the ip,peer ip and alias for each context if you use FT or 2 modules. With this setup i always need 4 IP's including the VIP per context on the client side.
Then you can configure the shared vlan in each context separate.
context A
allocate-interface vlan 10
allocate-interface vlan 20
context B
allocate-interface vlan 30
context C
allocate-interface vlan 40
sebastianvandijk Tue, 02/06/2007 - 03:23
I have this configured already :
context BACKEND
context FRONTEND
But how can i define 1 ip for vlan 40 on context BACKEND and 1 ip for vlan 40 on context FRONTEND ?
Correct Answer
Roble Mumin Tue, 02/06/2007 - 03:31
changeto BACKEND
conf t
interface vlan 40
ip address xyz
