Wireless Survey Help
Feb 6th, 2007
Recently my company has started doing lots of wireless surveys. The survey kit consists of a battery pack several AP's and antennas and what I belive to be a steel speaker stand as the survey pole. Once you have the AP and batttery pack on this thing it must weigh 30Kg which after a whole day of lugging around it too much.
My question is what do other people use for their survey pole, bearing in mind it needs to extend to ceiling height.
any suggestions would be greatly appreciated (apart from join a gym!)
Overall Rating: 5 (1 ratings)
eddig Tue, 02/06/2007 - 05:41
sounds fair enough. The battery pack I have also just provides PoE. I was really after a pole to get the AP to ceiling height, so one person can do a survey.
john.preves Tue, 02/06/2007 - 10:54
Currently, I use a painters pole that telescopes from 5 feet to 10 feet. I got some free paint sticks that I fastened to the top to tie wrap my antennas to. I then tie wrap the AP to the pole just at the top of the shortest position so the AP stays put while the antenna sraise up and down.
I fastened the pole to my rubbermaid utility cart with heavy duty velcro strips that would hold a buick against a brick wall. I can easily remove the pole by rotating it off the velcro when i need to get through doorways etc. For added security when I am not standing there so some clown doesn't knock over my stuff I have a velcro starp that cinches tight across the pole and leg of the cart. All Items purchased at home depot - McGyver would be impressed!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
