LMS Software
sachinraja Tue, 02/06/2007 - 04:18
Hello Sayed,
LMS software is not there for download or trial like ACS or CNA.. you need to procure the software and use it.. YOu can contact your local cisco partner and he should be able to help you with this....
Hope this helps.. all the best..
Raj
