Cisco PIX 501 to Cisco Concentrator 3005 via Remote Access
Answered Question
Feb 6th, 2007
Hello folks,
I need your help.
We got a Cisco PIX 501 in one location and this pix is configured for pppoe dial out. The pix connects itself to the internet via pppoe client. ping to an offical ip is running well.
So what I want to do is to establish a von tunnel between this pix and a cisco 3005 concentrator.
But I was not successull to establish it.
Here is the pix config. the acl?s are only for testing and will be replaced if it works.
PIX Version 6.3(4)
interface ethernet0 10baset
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname PIX-AU
domain-name araukraine.ua
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside permit ip any any
access-list inside_access_in permit ip any any
pager lines 24
logging on
logging monitor warnings
logging buffered warnings
mtu outside 1456
mtu inside 1456
ip address outside pppoe setroute
ip address inside 192.168.x.x 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.x.x 255.255.255.224 inside
pdm logging warnings 500
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group outside in interface outside
access-group inside_access_in in interface inside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa authentication ssh console LOCAL
http server enable
http 192.168.x.x 255.255.x.x inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 192.168.x.x 255.255.x.x inside
telnet timeout 5
ssh 194.39.97.0 255.255.255.0 outside
ssh timeout 5
management-access inside
console timeout 0
vpdn group pppoe_group request dialout pppoe
vpdn group pppoe_group localname [email protected]
vpdn group pppoe_group ppp authentication pap
vpdn username [email protected] password *********
encrypted privilege 15
vpnclient server 212.xx.xx.xx
vpnclient mode network-extension-mode
vpnclient vpngroup vpntest password ********
vpnclient username pixtest password ********
terminal width 80
on the concentrator I created a user pixtest, a group vpntest and I?ve created rules for the network e.g. to which server the users behind the pix will be able to access.
And that?s all.
I could not send you the output either of the pix or concentrator because I did not get an error or a message that the tunnel will be established.
What can be wrong ?
Thanks for the replies
Correct Answer by kaachary about 9 years 7 months ago
Hi..
You are missing the command "vpnclient enable" on the PIX.
HTH,
Kanishka
Correct Answer by smalkeric about 9 years 7 months ago
This sample configuration demonstrates how to form an IPsec tunnel from a PC that runs the Cisco VPN Client (4.x and later) to a Cisco VPN 3000 Concentrator to enable the user to securely access the network inside the VPN Concentrator.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a008026f96c.shtml
Overall Rating: 5 (2 ratings)
Correct Answer
kaachary Wed, 02/14/2007 - 05:22
Hi..
HTH,
Kanishka
