02-06-2007 05:28 AM - edited 03-10-2019 02:58 PM
Dear All,
I am using AAA ( ACS 3.3 ) in multi administrators and network support team member, I needs to limit network supporters on a specific group, but when doing this from administration control, the all still having full access on ACS certification setup and subcommands Generate Certification Signing Request and Generate Self-Signed Certificate. How can resolve this problem and deny access to Certificate Setup and
subcommand.
Na'am Awwad
02-07-2007 11:26 AM
Hi Na'am Awwad,
You need to create / edit an administrator account who does not have permission to ACS certificate setup. This can be done by unchecking the ACS certificate setup tickbox under administrator privileges.
ACS will show access denied to this administrator when he tries to access the acs certificate setup and sub commands since he does not have the required priveleges.
02-07-2007 10:53 PM
HI ALL,
I did it before posting first message but not working properly, note that the problem not on all ACS Certificate Setup, it is only on the following two subcommands,
Generate Certificate Signing Request
02-08-2007 11:38 PM
It should work as per what i have metioned. I manually tested the scenario you described and it works fine for me.
