Unable to establish BRI call
Feb 6th, 2007
I am trying to connect my 2811 to HiCom 150 via BRI. VIC2 - BRI-NT/TE is installed into 2811. I am using QSIG.
I cannot establish outgoing call from Cisco to HiCom with csim.
The ISDN portion seems to be Ok.
#sh isdn status BRI 0/0/0
Global ISDN Switchtype = basic-net3
ISDN BRI0/0/0 interface
dsl 0, interface ISDN Switchtype = basic-qsig
**** Slave side configuration ****
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Here is BRI config:
interface BRI0/0/0
no ip address
isdn switch-type basic-qsig
isdn overlap-receiving
isdn point-to-point-setup
isdn incoming-voice voice
isdn skipsend-idverify
voice-port 0/0/0
compand-type a-law
bearer-cap Speech
But the call cannot be established. The reason is "Invalid information element contents"
Here is complete debug:
#csim start 7122
csim: called number = 7122, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(19)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
*Feb 6 14:12:25.070: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x17 is 0x0 0x0, Called num 7122
*Feb 6 14:12:25.070: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x000F
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Called Party Number i = 0x80, '7122'
Plan:Unknown, Type:Unknown
*Feb 6 14:12:25.106: ISDN BR0/0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x800F
Cause i = 0x85E418 - Invalid information element contents
What can be the cause of such behaviour?
fmeetz Mon, 02/12/2007 - 06:50
This message "invalid information element contents" only shows up during debug q931 enabled. doesn't seem to impact the call connection.
