GRE - fast tunneling enabled - what does this imply?
Feb 6th, 2007
Hi - does anyone know the significance of the 'fast tunneling enabled' comment in the show interface tunnel'x' output below:
Tunnel120 is up, line protocol is up
Hardware is Tunnel
Description:
Interface is unnumbered. Using address of Loopback100 (x.x.90.101)
MTU 1514 bytes, BW 256 Kbit, DLY 500000 usec,
Encapsulation TUNNEL, loopback not set
Keepalive set (5 sec), retries 3
Tunnel source x.x.91.133 (Loopback50), destination x.x.136.19
Tunnel protocol/transport GRE/IP, key disabled, sequencing disabled
Tunnel TTL 255
Checksumming of packets disabled, fast tunneling enabled
Last input never, output 00:00:03, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2
Queueing strategy: fifo
Output queue: 0/0 (size/max)
3630570 packets input, 174267377 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
3641995 packets output, 175165679 bytes, 0 underruns
0 output buffer failures, 0 output buffers swapped ou
Richard Burts Tue, 02/06/2007 - 15:25
Richard
I found a paragraph which seems to explain this in terms of support for fast switching and CEF for GRE encapsulated traffic:
Encapsulation and the removal of encapsulation at the tunnel endpoints are slow operations; in general, only processor switching is supported. However, fast switching of GRE tunnels was introduced in Cisco IOS Release 11.1 for the Cisco 2500 series and the Cisco 4000 series of routers, and CEF switching of GRE tunnels was introduced in Cisco IOS Release 12.1.
If you want to see the original source here is the link:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1829/products_feature_guide09186a0080087091.html
Rick
