Showing the type of GBIC installed
Feb 6th, 2007
What command will show the types of GBICs that are installed in the ports of SCM-2GE or IOM-2GE modules? I've tried various combinations of the "show chassis" command (and others) and can't get it to show whether or not there is a GBIC inserted, or what model GBIC it is.
CSS 11506 07.40.1.03 or 07.50.1.05s.
bwalchez Mon, 02/12/2007 - 06:51
The show module command shows the type of GBIC installed in the ports.
show module Mod/ Ports
gzkjgs Mon, 02/12/2007 - 07:40
"show module" works on your CSS? I don't have the "show module" command (in llama either).
CSS11506# show module
%% Invalid input detected at '^' marker.
CSS11506# show m?
map Show MSD mapping
mibii Show MIBII extended information
mibii-32 Show MIBII information
CSS11506# show ver
Version: sg0750105s (07.50.1.05s)
Flash (Locked): 07.40.1.03
Flash (Operational): 07.50.1.05
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
Enhanced Feature Set
Secure Management
gzkjgs Thu, 02/15/2007 - 06:49
There's no "show inventory" command, but there is a "show chassis inventory":
CSS11506# show chassis inventory
Chassis Inventory:
Product Name: CSS11506-2AC E0 SW Version: 07.50.1.05s
Serial Number: JAB09xxxxxx Base Mac Address: 00-13-80-37-xx-xx
Slot Module Serial
1 CSS5-SCM-2GE F0 JAB0915xxxx
2 CSS5-SCM-2GE F0 JAB0914xxxx
3 CSS5-SSL-K9 F0 JAB0848xxxx
4 CSS5-IOM-2GE E0 JAB0808xxxx
7 CSS506-SM E0 JAB0911xxxx
8 CSS506-SM E0 JAB0911xxxx
No useful information there. Even a "show chassis verbose" command does not indicate the presence of a GBIC. It shows the Operational Status of a port as "online" whether there is a GBIC installed or not. For example, in the output below Slot 4 has a GBIC installed in port 4/1, but 4/2 is empty:
CSS11506# sho chassis verbose
Configuration for CSS11506-2AC E0:
Serial Number: JAB0916xxxx Base Mac Address: 00-13-80-37-xx-xx
Module(s) Found: 6
Power Supplies(s) Found: 2
Fan(s) Found: 3
Slot/SubSlot Operational Locked
1/1 *07.50.1.05 07.40.1.03
2/1 *07.50.1.05 07.40.1.03
3/1 *07.50.1.05 07.40.1.03
4/1 *07.50.1.05 07.20.2.06
Slot Number: 1 Type: CSS5-SCM-2GE F0
Serial Number: JAB0915xxxx Number of Ports: 2
Operational Status: primary
Port Number: 1 Port Name: SCM-2GE
Operational Status online
Port Number: 2 Port Name: SCM-2GE
Slot Number: 2 Type: CSS5-SCM-2GE F0
Serial Number: JAB0914xxxx Number of Ports: 0
Operational Status: backup
Slot Number: 3 Type: CSS5-SSL-K9 F0
Serial Number: JAB0848xxxx Number of Ports: 0
Slot Number: 4 Type: CSS5-IOM-2GE E0
Serial Number: JAB0808xxxx Number of Ports: 2
Port Number: 1 Port Name: IOM-2GE
Port Number: 2 Port Name: IOM-2GE
Slot Number: 7 Type: CSS506-SM E0
Serial Number: JAB0911xxxx Number of Ports: 0
Operational Status: powered-on
Slot Number: 8 Type: CSS506-SM E0
end of buffer.
I've tried "show int", "show phy", "show system-resources", I just can't find it. I'm starting to think nothing but a physical inspection will reveal the type of GBIC...
_TDHster_ Thu, 02/15/2007 - 12:22
Maybe show tech, but it is very cruelly... My be variance with show tech ? may simplify output anylize.
