Error installing DUC
Feb 6th, 2007
Hi All,
I tried to install Domino Unified Communications to Domino Server installed at AIX. Here is my environtment;
AIX version 5.3
Domino version 7.0.1
DUC ver 1.2.2
I followed the wizard with this parameter;
-owner of installes files : notes
-group that the installed files will belong to : notes
-path to notes.ini /local/notesdata
-path to program directories /opt/ibm/lotus/bin
but I found error "Unable to initialize the server API's".
thanks for any comment.
bongkie
sopayne Tue, 02/06/2007 - 09:28
Hi Bongkie,
It looks like you probably already have followed these steps:
You get the error 'Unable to initialize the server API's'
1. Make sure your notes user/group and path to your notes.ini are correct during server install
2. Make sure you have specified a valid user/group during the server install
3. Make sure the user you specified has Read/Write access to the system's
temporary directory.
4. Make sure your DUC server files have the proper permissions (see the tree below)
I found another instance where a customer experienced this same error when Domino was installed on a directory other than /opt/lotus.
Once the customer re-installed Domino on /opt/lotus and then DUCS, the problem was resolved and DUCS was properly configured.
I hope this helps.
bongkiekong Tue, 02/06/2007 - 21:10
sopayne,
thank you for the response.
I'm sorry if I miss understand what your point is.
do you think I have to re-installed the Domino?
if so, it's imposible to reinstalled the domino because it's will impact to the businnes and other risks.
any idea ?
thanks
