calling ID Restriction
Feb 6th, 2007
When dialling out from the local sites using 2821 ROUTER CLID is still being forwarded. BT the bri supplier have provided cli with held at the local exchange.
Paolo Bevilacqua Tue, 02/06/2007 - 18:22
And the question is ?
Using CallManager, the clir is restricted by a checkbox somewhere is the configuration.
In all the other cases, if you want CLIR (calling number information restricted), configure "clid restrict" in the outbound dial-peer. The outgoing setup message will be then like:
ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x40
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x00A0, '28293031' <-- NOTE i is set to 0xA0 to mean CLIR
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '68783347'
Sending Complete
