Easy VPN client
Answered Question
Feb 6th, 2007
Hi, I'm building a vpn using a Easy VPN server on 8xx adsl router and a remote client who uses xp pro.
Server side is configured but, when the documentation says "easy vpn client" it means vpn client 4.6 or 4.7 or 4.8 cisco vpn client? or is a especial software?
Best regards
Edgar Quintana
Correct Answer by ggilbert about 9 years 7 months ago
From the support standpoint, EasyVPN client means hardware client.
Like routers or PIX firewall connected as a client to the headend side. (which will be an EasyVPN server).
The normal software clients are called as VPN clients.
Overall Rating: 5 (1 ratings)
Correct Answer
ggilbert Mon, 02/12/2007 - 14:31
edgar-quintana Mon, 02/12/2007 - 14:35
thks for fast answering...
Now, I have a seriuos problem configuring easy vpn server on my cisco router..I've posted this problem.
Can you help me?
best regards
