cue dial by name directory
Feb 6th, 2007
Hello, have a new cue setup and I would like to change the dial by name directory to use the first name. is this something i'm going to have to script or is there a command that i can set this easily? thanks in advance!
Overall Rating: 4 (1 ratings)
cheramie-broussard Tue, 02/06/2007 - 10:03
I can easily get around the prompt by recording over it, Mark referenced a workaround for swapping first name and last name entries, but i don't see a place in rhe CUE for these entries. would that be in the username entry or on the mailbox itself?
rob.huffman Tue, 02/06/2007 - 10:21
Hi Cheramie,
I hate to keep referencing info from Markus, but he says it better than I could ever hope to :)
"The only way to search by first name is simply to reverse the first name/last name in each user's profile. Those fields are not used anywhere else, so it's not that big of a deal."
From this excellent (older) thread;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dd6ac82/0#selected_message
Hope this helps! And good luck!
Rob
