Decrease wireless signal
Feb 6th, 2007
I have several Aironet 1100 series APs and everything works fine. I would like to decrease the signal so it could only be reach in certain distance or area. Is there a way for me to do this?
Overall Rating: 4 (1 ratings)
rob.huffman Tue, 02/06/2007 - 13:37
Hi John,
You can decrease the radio coverage area of an AP when you modify the transmitter power level parameter. Have a look;
The transmitter power (mW) setting determines the power level of the radio transmitter. The default power setting is the highest transmit power allowed in a regulatory domain. Government regulations define the highest power level for radio devices.
Caution: The transmitter power level setting must conform to the established standards of the country in which the setting is used.
Generally, the transmitted power is reduced to limit the effect of RF interference. The reduction has a negative effect on the radio coverage. The transmitted power is directly proportional to the radio coverage area. Therefore, the weaker the transmitted power, the smaller is the radio coverage area.
If you perform a proper site survey, and remove possible sources of RF interference, you can use the lowest possible transmitted power value to decrease the radio coverage area.
This CLI command under the radio interface changes the transmitted power level to the maximum on an AP:
Access Point (config)# interface dot11radio 0
Access Point (config-if)# power local maximum Use this command to set the power level to maximum. Then, check how much throughput you have, and move the power level to a lower value until you reach a high throughput rate that stays consistent. You can also start from the lowest possible power level and increase the level until you reach a consistent throughput. This is because in some cases, if you do not boost the signal to the maximum level, the throughput and signal strength can change continuously and not remain consistent.
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_tech_note09186a00805190f1.shtml#topic5
Configuring Radio Transmit Power
From this good doc;
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_guide_chapter09186a00802085c3.html#wp1017196
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
