3750 EMI and SMI mixed mode?
Feb 6th, 2007
Hi Guys,I have a question about 3750?
1.Can I use them in EMI and SMI mix mode?
2.If OK, what happening if I put EMI switch as Master,the other SMI as slave? Is Auto Upgrade IOS working ?
Thanks in advanced.
Peng
glen.grant Tue, 02/06/2007 - 15:06
If the EMI is master it should upgrade the code if you have the " boot auto-copy-sw" in your running config for the master.
pengfang Tue, 02/06/2007 - 15:28
thanks for reply,
1.Any hardware requirement for upgrade to EMI firmfware ?
2.Sorry maybe this is stupid question, do I need to purchase additional license to upgrade each of SMI switch to EMI switch?
sachinraja Tue, 02/06/2007 - 16:06
Hello Peng,
There is no hardware upgrade required for SMI to EMI.. its just that you will need to upgrade the software, with licenses.. There is a basic upgrade license in Cisco which you might need to procure.. If i'm not wrong, the part code is CD-3750-EMI.. Get in touch with your Cisco partner to know more on this !!!
Raj
