1800 + Wireless
Feb 6th, 2007
I have configured the 1800 wireless interface however nobody can connect to the SSID.
Any ideas,
Below you can find the config:
aaa new-model
aaa authentication login default local
aaa session-id common
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.40.1.1 10.40.1.50
ip dhcp pool LAN
network 10.40.1.0 255.255.255.0
default-router 10.40.1.1
dns-server 10.10.3.22 10.10.3.23
bridge irb
interface FastEthernet0
description FW_OUT
no ip address
load-interval 30
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
spanning-tree portfast
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
ssid test
vlan 1
authentication open
authentication key-management wpa
wpa-psk ascii 7 test
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 2312
channel 2462
station-role root
no dot11 extension aironet
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no snmp trap link-status
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description FW_Inside
ip address 10.20.30.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Async1
no ip address
encapsulation slip
shutdown
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
no cdp enable
ppp chap hostname test
ppp chap password 7 test
interface BVI1
ip address 10.40.1.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer1 overload
access-list 100 permit ip 10.40.1.0 0.0.0.255 any
control-plane
bridge 1 route ip
