PIX Site to Site VPN problems
Answered Question
Feb 6th, 2007
Hi, I currently have a site to site vpn up and running and it's working fine. I'm trying to bring two more online and just can't get them working. I used the same config from the working one but I can't get the tunnel to come up. I've seen various errors while debugging isakmp and ipsec and they are at the end of my configs. Anybody have any ideas? Thanks
Main site - has vpn clients connecting too it and pt to pt vpn's to 3 endpoints
Cisco PIX Firewall Version 6.3(3)
** Main Site Config **
access-list client_vpn permit ip 10.10.0.0 255.255.0.0 192.168.0.0 255.255.255.0
access-list VPN_to_Site2 permit ip 10.10.0.0 255.255.0.0 192.168.0.0 255.255.255.0
nat (inside) 0 access-list client_vpn
sysopt connection permit-ipsec
crypto ipsec transform-set fws_encry_set esp-3des esp-md5-hmac
crypto map outside_map 60 ipsec-isakmp
crypto map outside_map 60 match address VPN_to_Site2
crypto map outside_map 60 set peer 64.X.X.19
crypto map outside_map 60 set transform-set fws_encry_set
crypto map outside_map interface outside
isakmp enable outside
isakmp key ******** address 64.X.X.19 netmask 255.255.255.255 no-xauth no-config-mode
isakmp identity address
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
Site 2 config
** only because pt to pt doesn't work i have it setup to allow vpn clients to pass through it to connect to the main site.
Cisco PIX Firewall Version 6.3(5) **
access-list VPN_to_Main permit ip 192.168.0.0 255.255.255.0 10.10.0.0 255.255.0.0
nat (inside) 0 access-list VPN_to_Main
crypto map outside_map 10 ipsec-isakmp
crypto map outside_map 10 match address VPN_to_Main
crypto map outside_map 10 set peer 207.X.X.13
crypto map outside_map 10 set transform-set fws_encry_set
isakmp key ******** address 207.X.X.13 netmask 255.255.255.255 no-xauth no-config-mode
Errors
PIX(config)# IPSEC(sa_initiate): ACL = deny; no sa created
authenticator is HMAC-MD5IPSEC(validate_proposal): invalid local address
I have an existing link that works fine. I copied the config from there, changed the ip info and it won't work. The only diffences in the configs are no sysopt route dnat and it's on Version 6.2(2)
Correct Answer by Ajit Singh about 9 years 7 months ago
I believe you configured a VPN tunnel without removing the crypto map from the outside interface. The above message is the error we get under such situation.
I would suggest you the following workaround:
- remove the crypto map from the outside interface ( Both pix)
- Clear cry isa sa and clear cry ipsec sa ( both pix)
- Re-apply the crypto map on the outside interfaces.
If this do not resolve the issue, reboot the devices.
Ajit
Overall Rating: 4 (2 ratings)
sachinraja Tue, 02/06/2007 - 22:50
Did you also copy/paste the pre-shared keys ? can you manually enter on both the sides and try ? Can you give us some more debug outputs ?? I hope you tried the ACL VPN_t-Site2 on your nat 0 statement before ? Are there any other ACL's on the inside interface ?
Raj
itfwsteel Wed, 02/07/2007 - 09:54
Yes I did try entering the pre-shared keys again , that was one of the first things I suspected. The debug only gives me
As for ACL's, I do have the standard, inside acl for all outbound traffic. My nat 0 is for ACL client_vpn which handles both the point to point vpn's and the client. As you can see on the crypto statements the VPN_to_Main is the ACL that handles the 'interesting' traffic for that network to be encrypted.
Like I said, as it is now it's working with one site just fine and this new site I setup exactly the same, no go and I don't see why?
Thanks for the help
Jon Marshall Wed, 02/07/2007 - 10:11
This is the official response on the error message from Cisco:-
"%PIX-3-302302: ACL = deny; no sa created
Explanation IPSec proxy mismatches. Proxy hosts for the negotiated SA correspond to a deny access-list command policy.
Action Check the access-list command statement in the configuration. Contact the administrator for the peer."
Having said that i have come across this quite a few times before when setting up VPN's. Always on the device initiating the tunnel. Sad to say that rebooting the device more often than not sorted the problem out. Yes it's not a very good solution but the Pix seems to get itself into a bit of mess sometimes.
Jon
sachinraja Tue, 02/13/2007 - 20:08
Hello brian,
do you still have issues with this ? If so please let us know....
Raj
Correct Answer
Ajit Singh Tue, 02/27/2007 - 17:40
Ajit
