IPCC Prompt recording
mikeconiglio Tue, 02/06/2007 - 18:47
You can use Unity to leave a message, i.e. prompt and then save the file to whatever you want and then upload to IPCC.
gshontin Wed, 02/28/2007 - 18:48
You don't need a seperate codec, just the right format wav. Use sound recorder. When you select save, click on the Format... Change Button.
In the Format Drop down select CCITT u-Law
In the Attributes drop down select 8kHz, 8-bit, Mono 7 kb/sec.
Save file. This is the only format IPCC works with
