problem in layer 3 switch
Feb 6th, 2007
respected sir
iam anil bhardwaj Sen Network Engineer in Nahr Group Of Companies at Ludhiana (India). We have cisco 3 layer switch of 3560 series.We face the problem that when we attached our three sun solrise server with this switch then its ports LEDs starts blink amber color. it blinks amber color only for one or two mintus.when it blinks amer our working speeds becomes slow. we have already chane its cables,with which we have attached the servers. The lan card of server are 10/100/1000 speed. we have already set full duplex mode .we have also change the ports but the problem is still remaining. pls tell me the solution
Best regards
Anil bhardwaj(Sen Network Engineer)
Nahar Group of companies
Ludhiana (India)
Mob:-09872645764
E-Mail :[email protected]
spremkumar Tue, 02/06/2007 - 20:48
Hi Anil
Can you check your logs in your 3560 Switch ?
Logs will provide vital details for your to troubleshoot what might be going wrong in your switch.
You can check out the same using show log command in your switch..
do make sure that you have enabled logging before using the command show log.
regds
anilbhardwaj Tue, 02/06/2007 - 21:29
sir
i have not check the log. i dont know how to check the log. i want ot tell u the problem in detail.
we have puchaged ths switch 15 months ago. we have also another 3550 series. the configuratons of both switch are same. we have copy the configuration the 3550 series switch in 3560 series switch. when we connect the server with 3550 series switch then it works properly but when we connect the sever with 3560 seris switch the its Port LEDs starts amber color. if there is possible then pls send me detail in to my email,how i check the swicth. My e-Mial id is [email protected]
sachinraja Tue, 02/06/2007 - 21:55
Hello Anil,
is the 3560 a gigabit enabled one ?? check if there are any speed/duplex mismatches between the switchport and the server.. you can run auto/ auto or best thing is to force the speed/duplex to 100/full... Check this and let us know... also enable "portfast" on the switchport to make sure the switch comes online soon....
All the best...
Raj
