Equivaliant command for Show Logging Buffer 1023
Answered Question
In CatOS you could enter the command "Show logging buffer 1023" to see an activity log in Catalyst switches running CatOS. Is there an equivaliant command for IOS switches? Thank you.
Correct Answer by sachinraja about 9 years 7 months ago
hello,
you just need to use a Show logging command... refer to the following URL:
http://cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00807743e8.html
Raj
Correct Answer by ankbhasi about 9 years 7 months ago
Hi Friend,
Have you tried "sh log"?Should work.
Ankur
Overall Rating: 5 (2 ratings)
Correct Answer
ankbhasi Wed, 02/07/2007 - 00:59
Hi Friend,
Ankur
