E1 WIC for Unframed
Feb 7th, 2007
My E1 controller card is not supporting unframed E1 connection.My E1 card details are below mentioned.
E1 0/0 is down.
Applique type is Channelized E1 - balanced
Description: WAN INTERFACE
Far End Block Errors Detected
Receiver has loss of signal.
alarm-trigger is not set
Version info Firmware: 20040108, FPGA: 11
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 0.
Data in current interval (873 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 873 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 873 Unavail Secs
Data in Interval 1:
0 Slip Secs, 900 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
Data in Interval 2:
Data in Interval 3:
spremkumar Wed, 02/07/2007 - 01:21
Hi Murthy
Can you confirm whether you have tried configuring channel-group 1 unframed under controller config ?
regds
spremkumar Wed, 02/07/2007 - 02:04
Can you paste the output of show version and show diag here ?
regds
kvnmurthy Thu, 02/08/2007 - 21:28
Sorry for the delay, here is the sh diag command output
show diag
Slot 0:
C2610XM 1FE Mainboard Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 3.1
PCB Serial Number : FOC08290FRH (433153135)
Part Number : 73-7677-05
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : A0
Deviation Number : 0-0
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 6A 41 03 01 C1 17 46 4F 43 30 38 32
0x10: 39 30 46 52 48 20 28 34 33 33 31 35 33 31 33 35
0x20: 29 82 49 1D FD 05 04 00 81 00 00 00 00 42 41 30
0x30: 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
--More-- WIC Slot 0:
E1 (1 port) WAN daughter card
Hardware revision 1.0 Board revision F0
Serial number 32594159 Part number 800-04475-03
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 21 01 00 01 F1 58 EF 50 11 7B 03 00 00 00 00
0x30: 78 00 00 00 04 08 22 00 FF FF FF FF FF FF FF FF
Router#
kvnmurthy Thu, 02/08/2007 - 21:30
Router#sh ver
IOS (tm) C2600 Software (C2600-IPBASE-M), Version 12.3(6c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 20-Jul-04 05:24 by kellythw
Image text-base: 0x80008098, data-base: 0x80ED06CC
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Router uptime is 7 minutes
System image file is "flash:c2600-ipbase-mz.123-6c.bin"
cisco 2610XM (MPC860P) processor (revision 0x301) with 126976K/4096K bytes of memory.
Processor board ID FOC08290FRH (433153135)
M860 processor: part number 5, mask 2
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
1 Channelized E1/PRI port(s)
--More-- 32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Router#
rdessert Fri, 02/09/2007 - 06:36
To configure it for unframed try this:
conf t
controller e1 0/0
no framing crc4
Hope this helps.
handoko.wiyanto Fri, 02/09/2007 - 09:38
hi there,
as my understanding, you are trying to configure E1 as unframed, means for data, correct?
afaik, your e1 card must support g703 for unframed.
what e1 card are you using now?
