Use FastEthernet port as uplink (Cisco 3500)
Feb 7th, 2007
Hey,
I have a Cisco 3500 with 48 port and 2 uplink ports. When i use a fastethernet port as uplink i get the following error:
"%SPANTREE-2-BLOCK_PORT_TYPE: Blocking FastEthernet0/42 on vlan 1.Inconsistent port type." and the port is disabled. I tried several spanning-tree modes and mode trunk on that port but it is still not working. I cleared the configuration from the switch before i started. The two other uplink port working fine but on that location we don't have glassfibre. :-(
glen.grant Wed, 02/07/2007 - 01:50
Try deleting the vlan.dat file in flash and reboot the switch and start over.
systembeh Wed, 02/07/2007 - 03:03
I done it!
I found a document with the solution. Try this:
interface FastEthernet0/1
port group 1
encapsulation dot1Q.
switchport mode trunk
Now you can use port 1 as uplink from another switch. I don't know how, but it does.
(I'm happy now)
