Wireless AP1120 upgrade problems
Feb 7th, 2007
I am trying to upgrade my wireless basestation to the latest release of software from 12.2(13) when trying http and the tftp options it failes everytime, cant get them to upgrade.
anyone any ideas,
frankzehrer Wed, 02/07/2007 - 04:40
i need some more informations.
What are the used tftp options?
archive download-sw /overwrite /reload tftp:[[//location]/directory]/image-name
You should use the overwrite switch in the archive command. The AP has in its standard hardware configuration not enough memory to hold two images.
Do you get some failure message?
Best regards,
Frank
iainporter Wed, 02/07/2007 - 06:12
cheers Frank,
used the overwrite command I found in a previous post, worked a treat.
thanks for your time and response.
Iain
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
