NTP Question
Answered Question
Feb 7th, 2007
Hi, I have a 6500 Catalyst with an NTP server configured
- ntp server <IP_ADDR_NTP_SRV>
if I give the command
- clock calendar-valid
does the Catalyst still use the NTP server for synchronizing the clock and calendar as long as there is connectivity with it?
In a network layout like:
NTP --> Cat6500 --> Other_Catalyst
is it better to synch the Other_Catalyst with the NTP allowing "ntp broadcast" on the Cat6500 or is it better to Synch the Other_Catalyst with the Cat6500?
Thank you.
Correct Answer by Richard Burts about 9 years 7 months ago
Luigi
The catalyst should still use the NTP server for synchronizing the clock.
I would think it is better to sync the other catalyst with the Cat6500.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Wed, 02/07/2007 - 04:54
Luigi
Rick
