DSL PPPoE brige to PIX
Feb 7th, 2007
I have 2 ISPs,1st terminated on DLink 502T router using PPPoE, and 2nd terminated on PIX 501 directly and uses VPN. Both ISPs are having static IP. I now wish to scrap the 2nd ISP bcoz of inconsistency, and only use the 1st ISP.
I am trying to do a bridge with 502T and PIX 501. But I get the following error, while i try shifting my PIX from STATIC to PPPoE:
[ERR]ip address outside pppoe
Can not enable PPPoE on the same interface as vpdn.
What possibly am I doing wrong?
Overall Rating: 5 (1 ratings)
swapniljain Wed, 02/07/2007 - 23:55
Ratnakar,
let the pppoe be on the dlink, give a dummy ip on pix and dlink and enable DMZ on dlink to forward all traffic to your public ip to the pix ip. if this solves your problem rate me.
Swapnil Jain
mukeshjain Thu, 02/08/2007 - 00:16
i had the same problem
i think u cant set pppoe if vpn i enabled
thanks swapnil
even i was looking for this
mj
