SOL !!! plz chk the configuration ?????
Feb 7th, 2007
plz cck also the attached network PIc,
I have to provide bandwidth to the Customer router of 2 MB.
Router-A is our core router(BGP running).
Router-B is edge router("static routing" we are using it for our provate network).
Customer router need 2MB
Plz chk the E1 config and suggest!!!!
Router A
ccontroller E1 0/1
clock source internal
channel-group 1 timeslots 1-31
nterface Serial0/1:1
bandwidth 2048
ip address 192.168.15.1 255.255.255.252
Router B
(For A router)
controller E1 0/1
clock source line primary
ip address 192.168.15.2 255.255.255.252
(For Customer router)
controller E1 0/0
channel-group 0 timeslots 1-31
interface Serial0/0:0
ip address 192.168.14.1 255.255.255.252
ip route x.x.x.x .x.x.x.x s0/1:1
Coustomer Router
controller E1 0/0
description LHR-ISB
description LHR-ISB
ip address 192.168.14.2 255.255.255.252
Routing
ip route x.x.x.x .x.x.x.x s0/0:0
plz sugget if there is any problem is the above config..
Best regards
spremkumar Wed, 02/07/2007 - 02:58
Hi Afzaal
If you are providing public ip space to the customer Local area network then you need to route the traffic pointing towards the serial which is connecting towards the customer end.
Also make sure you have the reachability to the customer local area network from your core router.
Once the same is done you can verify the same by checking reverese trace from any of the route servers..
regds
