vrf with pppoe
Feb 7th, 2007
Good day,
I try a test lab yesterday. I configure a router as NAS:
This router terminate the pppoe and assign vrf to each client via a radius server. But i see that when pppe client belong to a vrf it doesn't receive ip address, there is not problem with authentication.
Linux free Radius configuration:
Service-Type = Framed-User,
Framed-Protocol = ppp,
cisco-AVPair = "lcp:interface-config=ip vrf forwarding MTNNS-NET",
Framed-IP-Address = 3.3.3.2,
Framed-IP-Netmask = 255.255.255.0,
cisco-avpair="lcp:interface-config=encapsulation ppp",
cisco-avpair="lcp:interface-config=ip address 3.3.3.3 255.255.255.0",
Router configuration:
aaa new-model
aaa authentication ppp default group radius
aaa authorization network default group radius
vpdn enable
vpdn-group 1
access dialin
protocol pppoe
virtual template 1
interface f0/0
description connection to server
ip address 1.1.1.1 255.255.255.0
interface f0/1
description client acces
ip address 2.2.2.2 255.255.255.0
pppoe enable
natamen Tue, 04/03/2007 - 12:24
did you get to a solution for this issue?
I am in the need of providing a similar solution: vrf with PPPoE. I still cant find the way to do it so I would appreciate any help.
As far as I can see, this solution is supported by means of a Radius server.... do you know if there is a way to do this manually, I mean that the config is static and resides in the PE?
Thanks a lot in advance,
Nataniel
ilya.varlashkin Tue, 04/03/2007 - 13:08
You don't need an address on fas0/1 just to get pppoe working, but it's ok to have it there if you need it for other reasons. Your posted config doesn't contain config of Virtual-Template 1 interface. Do you have it?
lcp:interface-config =
ip vrf forwarding \n
ip address
(Above is single line in RADIUS profile)
Is all what you need to get an IP address on the interface. No ppp, no anything of that kind - all general and common configs go to Virtual-Template.
Hope this helps.
