CPU Interface 0 storage notify failed on queue 1
Feb 7th, 2007
hi guys,
need help in this debug message that i have received on my cisco catalyst 3500 series switch
(IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.3)WC(1))
below is the debug message:
00:03:25: CPU Interface 0 storage notify failed on queue 1 by cisco Systems, Inc.
1d08h
00:03:27: CPU Interface 0 storage notify failed on queue1 Image text-base: 0x00003
00:03:27: CPU Interface 0 storage notify failed on queue 1 519958
Initializing C3500XL flash...tart_time
00:03:29: CPU Interface 0 storage notify failed on queue 18tellite dm 1 state 1 id 519CD8 ex flashfs[1]: 0 orphaned
00:03:29: CPU Interface 0 storage notify failed on queue 1te dm 0 state 1 id 519
flashfs[1]: Total bytes: 3612672te
00:03:31: CPU Interface 0 storage notify failed on queue 14008h: start_timer id mismatch sa
flashfs[1]: Bytes availa
00:04:59: CPU Interface 0 storage notify failed on queue 1stEthernet0/3 is up, line protocol is upe notify failed on
00:05:49: CPU Interface 0 storage notify failed on queue 1amic Host Configuration Protocol status
1d08h: CPU Interfa
00:05:49: CPU Interface 0 storage notify failed on queue 1 Show runtime diagnostic infod08h: CPU Interface 0 s
00:05:51: CPU Interface 0 storage notify failed on queue 1tal facilitiesdriver debug
1d08h: CPU Interface 0 storage
00:05:51: CPU Interface 0 storage notify failed on queue 1 state 1 id 5193D8 ex
1d08h: CPU I
exception ex
1d08h: CDP-PA: version 2 pa
history
00:05:55: CPU Interface 0 storage notify failed on queue 1bitEthernet
hosts IP
00:05:57: CPU Interface 0 storage notify failed on queue 1
1d08h: IFS: Stat: path flash:config.textLAN Virtual
00:05:57: CPU Interface 0 storage notify failed on queue 1et sent out on FastEthernet0/2598
interfaces
00:05:59: CPU Interface 0 storage notify failed on queue 1age notify failed on queue 1ellite
ip IP
00:05:59: CPU Interface 0 storage notify failed on queue 1 TTY line information
1d08h: start_ti
1d08h: CDP
00:06:01: CPU Interface 0 storage notify faie syste
00:06:15: CPU Interface 0 storage notify failed on queue 1t+user equivalencesg all
1d08h: CPU Interfa
1d08
00:06:16: start_timer id mismatch satellite dm 0 state 1 id 5199D8 exp id 519C18
rps Show the Redundant Power System (RPS) statusd on queue
00:06:16: start_timer id mismatch satellite dm 1 state 1 id 519A58 exp id 51A618t operating configurationut detected at '^' marker.
1d08h: CPU
00:06:16: start_timer id mismatch satellite dm 2 state 1 id 519B58 exp id 519CD8Interface 0 storage notify fai
snmp snmp statisticsue 1
stat
00:06:17: CPU Interface 0 storage nee Spa
00:06:19: CPU Interface 0 storage notify failed on queue 1on Interface FastEthernet0/20, cha
1d08h: CPU Interf
vla
00:06:19: IFS: Stat: path flash:config.text
state
vmps
00:06:19: CDP-PA: version 2 packet sent out on FastEthernet0/5rm] down
vtp VTP information
1d08h: CP
This may severely impact network performance. Continue? [
1d08h: start_timer id mismat
All possible
what does this "CPU Interface 0 storage notify failed on queue 1" debug message mean?
please advice...
Brian,
I seem to recall that 2900XL and 3500XL showed these "debug Cpu" messages in older IOS releases. The 12.0(5.3)WC(1)) code you have may still have some mem/cpu related caveats that may be symptomatic of this issue.
I know these boxes are EOL, maybe you can try to find away to get the last/latest IOS image in this train.
If I saw this on a supported box 3550/3560, I would surmize a mem issue and open a TAC case.
Hope this helps.
Bill
