PIX Dynamic NAT Issue
Feb 7th, 2007
Here is the setup:
Scenario A
1. The network 1.1.1.0/23 is dynamically translated to 5.5.5.5 when accessing the resources 7.7.7.7 and 8.8.8.8 on port 443. This has been working for months, then last week it stopped working.
Scenario B
1. To resolve the problem on scenario A, host within the 1.1.1.0/23 network were statically translated to individual IP addresses. This is now working.
Scenario C
Another solution for scenario A is scenario C, the network 1.1.1.0/23 is translated to 5.5.5.5 upon reaching PIX, Identity NAT is applied and this setup is working.
Questions:
What caused the dynamic NAT to stopped working?
How can we restore dynamic NAT from working again?
Isolation shows that Static and Identity NAT are working.
NOTE: IP addresses here are not the actual IP Addresses in production.
astanislaus Wed, 02/07/2007 - 05:28
Sorry. I thought the attaching file was not working and hence by mistake attached same diagram thrice.
Jon Marshall Wed, 02/07/2007 - 05:33
Could you send the config of the pix.
Also could you let us know which scenario you are currently running so the pix config makes sense.
Jon
