AAA on 6513 switch
Feb 7th, 2007
In 6513 the AAA config not working
Richard Burts Wed, 02/07/2007 - 07:29
Vijay
You have not given us much to work with here. The problem could be a configuration mistake on the 6513, it could be that the 6513 is not properly configured on the AAA server, it could be that the key used is not the same on both devices.
Posting the AAA configuration of the 6513 would be a good place to start. Also it would help if you would verify that there is IP connectivity between the 6513 and the AAA server. You could also look into the logs on the AAA server under failed attempts and tell us if there is any error message when you attempt AAA from the 6513.
If you can provide us some of the things I have asked for we may be able to find the solution to your problem.
Rick
pbvijay143 Wed, 02/07/2007 - 07:56
Hi Rick
here the configuration
aaa new-model
aaa group server tacacs+ ACS
aaa authentication login default local
aaa authentication enable default none
aaa session-id unique
tacacs-server host x.x.x.x
no tacacs-server directed-request
tacacs-server key xxxxxxxx
The IOS verison is 12.2(18)SXD6,
Richard Burts Wed, 02/07/2007 - 08:12
Vijay
I have looked at the config that you posted. I note that you are specifying local authentication for login to user mode and no authentication for enable mode. That is a slightly unusual combination, but if that is what you want you can do it.
Perhaps we need to clarify what the problem is. Your original post said that AAA was not working. I assumed that you were trying to communicate with an AAA server, but that is not what the config is doing. So perhaps you can clarify what about the AAA is not working.
Rick
