Can't delete an in-use nat static mapping
DaleKnutsen
Through an unfortunate combination of circcumstances, my router's configuration now has TWO instances of "ip nat inside source static ..." for a single inside address:
ip nat inside source static tcp 192.168.1.36 80 interface FastEthernet0 80
ip nat inside source static 192.168.1.36 69.228.xxx.xxx route-map SDM_RMAP_1 extendable
When tried to delete one of these static mappings, it said it was "in use" and refused to delete it. How can I delete an in-use static mapping?
mheusinger
Level 10
Level 10
clear the respective nat entry from the NAT table first and remove the command afterwards. It might require VERY fast typing, so copy and paste in the config mode usually works best:
do clear ip nat translation *
no ip nat inside source static 192.168.1.36 69.228.xxx.xxx route-map SDM_RMAP_1 extendable
This is SERVICE affecting!
Hope this helps!
Regards, Martin
mheusinger
Level 10
Level 10
Hope this helps!
Regards, Martin
