02-07-2007 07:02 AM - edited 03-05-2019 02:12 PM
Hi!
My 3750 accepts the "rate-limit" command, but does not seem to be rate-limiting...is the rate-limit command supported in the 3750 series
02-07-2007 07:43 AM
are you talking about 3750 router or Catalyst 3750? Which IOS version? Did you check the "unsupported commands" section of the configuration guide?
Usually the suitable command is "police" inside a policy-map.
Have a look at f.e. "Policing and Marking"
If you have a router, then this should be helpful: "Policing and Shaping Overview"
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080465b25.html
Hope this helps! Please use the rating system.
Regards, Martin
02-07-2007 10:12 AM
Thanks for your reply. This is helpful.
