Router 1811
Feb 7th, 2007
I see that this router has 2 interfaces 10/100 and also an 8 port switch.
I was wondering if it is possible that this switch may be splited in VLAN-s and one interface may be used as Router on a stick?
Also, there is one more slot for an additional interface. Can this slot accept an ethernet interface so i can get another network?
What type of card would it be?
KlediBodinaku24 Fri, 02/09/2007 - 02:08
Does this mean that i can use each port of the switch as a sub interface.
For that do i have to configure one of the FE ports as Router on a Stick and connect to the switch, or this Router can use each of these switch port as a sub interface and i can use the FE ports for other networks?
