02-07-2007 07:49 AM - edited 03-14-2019 07:54 PM
hi there...
im covering down on a system that has the 2940 switch and and avaya ip phone 4620..
i know that phone works but when i plug it into this switch it doesnt work... or it doesnt power on using the inline power from the switch...
i have tried adding it to a vlan but no luck...
though on a different system it works... i have read the config file and there are no vlans...
so... i know that i am missing something important... but what???
thanks
02-07-2007 08:01 AM
The phone will not power on because the Catalyst 2940 does not support the IEEE 802.3af power over ethernet standard required to power the Avaya 2940 IP Phone.
02-07-2007 08:07 AM
thanks for the quick response....
so is there anything that i can do about it...
i dont have a power adapter for the darn thing...
