WS-X6548-GE-TX and WS-X6748-GE-TX compatibility
Feb 7th, 2007
Currently, I am using the module in this combination:
Cat 6509 SUP720 + WS-X6748-GE-TX
Cat 6509 SUP2U + WS-X6548-GE-TX
Can I swap 6748-GE-TX with 6548-GE-TX?
Thus:
Cat 6509 SUP720 + WS-X6548-GE-TX
Cat 6509 SUP2U + WS-X6748-GE-TX
Does both WS-X6548-GE-TX and WS-X6748-GE-TX compatible if I do not have any voice application?
Overall Rating: 4.5 (2 ratings)
Jon Marshall Wed, 02/07/2007 - 09:57
Just to follow up on previous post.
You can use a 6548-GE-TX with both the Sup720 or the Sup2. The 6548-GE-TX is fabric enabled. With a Sup2 you need a separate Switch Fabric Module, otherwise the 6548 just connects to the shared 32Gbps bus. A Sup720 has a switch fabric module built in so the 6548 would connect to the switch fabric.
The 6748-GE-TX can, as the previous poster said, be used only with the Sup720.
Jon
