easy vpn client
Feb 7th, 2007
I have a link between 2 or more 1811 and I would like to use the hub as vpn server and spoke as vpn client.
My problem is that it seems that I can have only one network from from spoke.
Is it possible to have more than one network to pass into the vpn tunnel.
regards
Overall Rating: 5 (1 ratings)
ggilbert Wed, 02/07/2007 - 15:30
Eric,
Can you please explain if you are trying to build a Lan-to-Lan tunnel between these routers are you want to set up a EasyVPN network.
If you are trying to configure EasyVPN, you can have multiple subnets. (Only in Network Extension Mode)
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801541d5.html#wp1098057
Cheers,
Gilbert
Rate it, if it helps.
