Error adding users in Call Manager
Feb 7th, 2007
When I am trying to add users in call manager I am getting the following error "The phone administrator is currently not allowed to add or delete users" I have verified the access rights for the user and they appear to be correct.
jason-calbert_2 Wed, 02/07/2007 - 11:47
Is this active directory integrated or is this DC directory. Need this information to solve the problem.
jason-calbert_2 Wed, 02/07/2007 - 12:07
You might try and run adminutility to see if all of your passwords are in synch. Run this in non business hours because it restarts services.
Please rate helpfull posts
jason-calbert_2 Wed, 02/07/2007 - 13:10
Try this before you run the utility.
Step 1. select start > Run and type regedit
Step 2. Go to the following key:
HKEY_LOCAL_MACHINE>SOFTWARE> Cisco Systems, INC. > Directory Configuration
Step 3. You should see a key named DIRACCESS. By default, the value of this key is set to False. Change the value of this key to true.
Step 4. Restart the IIS ADmin Service.
oneillb Thu, 02/08/2007 - 07:51
I tried changing the registry and this did allow me to bring up the page to enter the user information. However when I press insert then I get an error.
