Command authorization error when using aaa cache
Feb 7th, 2007
I'm trying to use the aaa cache mode for command authorization. But when I execute a command there is always an error message:
% tty2 Unknown authorization method 6 set for list command
The command is then always authorized against the tacacs server.
The 'authentication login', 'authentication enable' and 'authorization exec' are using the cache properly.
I have tried it with an Accesspoint AIR-AP1242AG-E-K9, IOS 12.3(8)JEA and a Catalyst WS-C3550-24PWR-SMI, IOS 12.2(35)SE with the same results.
Deleting the cache entry and using only the tacacs group the error message disappears.
Any suggestions?
Thanks.
Frank
config
aaa new-model
aaa group server tacacs+ group_tacacs
server 10.10.10.10
server 10.10.10.11
cache expiry 12
cache authorization profile admin_user
cache authentication profile admin_user
aaa authentication login default cache group_tacacs group group_tacacs local
aaa authentication enable default cache group_tacacs group group_tacacs enable
aaa authorization console
aaa authorization config-commands
aaa authorization exec default cache group_tacacs group group_tacacs local
aaa authorization commands 15 default cache group_tacacs group group_tacacs local
aaa accounting exec default start-stop group group_tacacs
aaa cache profile admin_user
profile admin no-auth
aaa session-id common
tacacs-server host 10.10.10.10 single-connection
tacacs-server host 10.10.10.11 single-connection
tacacs-server directed-request
tacacs-server key 7 <removed>
debug output
ap#
Feb 7 20:02:37: AAA/BIND(00000004): Bind i/f
Feb 7 20:02:37: AAA/AUTHEN/CACHE(00000004): GET_USER for username NULL
Feb 7 20:02:39: AAA/AUTHEN/CACHE(00000004): GET_PASSWORD for username admin
Feb 7 20:02:42: AAA/AUTHEN/CACHE(00000004): PASS for username ^->o
Feb 7 20:02:42: AAA/AUTHOR (0x4): Pick method list 'default'
Feb 7 20:02:42: AAA/AUTHOR/EXEC(00000004): processing AV cmd=
Feb 7 20:02:42: AAA/AUTHOR/EXEC(00000004): processing AV priv-lvl=15
Feb 7 20:02:42: AAA/AUTHOR/EXEC(00000004): Authorization successful
ap#
Feb 7 20:02:54: AAA: parse name=tty2 idb type=-1 tty=-1
Feb 7 20:02:54: AAA: name=tty2 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=2 channel=0
Feb 7 20:02:54: AAA/MEMORY: create_user (0xBA9C34) user='admin' ruser='ap' ds0=0 port='tty2' rem_addr='10.10.1.1' authen_type=ASCII service=NONE priv=15 initial_task_id='0', vrf= (id=0)
Feb 7 20:02:54: tty2 AAA/AUTHOR/CMD(787222339): Port='tty2' list='' service=CMD
Feb 7 20:02:54: AAA/AUTHOR/CMD: tty2(787222339) user='admin'
Feb 7 20:02:54: tty2 AAA/AUTHOR/CMD(787222339): send AV service=shell
Feb 7 20:02:54: tty2 AAA/AUTHOR/CMD(787222339): send AV cmd=show
Feb 7 20:02:54: tty2 AAA/AUTHOR/CMD(787222339): send AV cmd-arg=running-config
Feb 7 20:02:54: tty2 AAA/AUTHOR/CMD(787222339): send AV cmd-arg=<cr>
Feb 7 20:02:54: tty2 AAA/AUTHOR/CMD(787222339): found list "default"
Feb 7 20:02:54: % tty2 Unknown authorization method 6 set for list command
Feb 7 20:02:54: AAA/AUTHOR (787222339): Post authorization status = ERROR
Feb 7 20:02:54: tty2 AAA/AUTHOR/CMD(787222339): Method=group_tacacs (tacacs+)
Feb 7 20:02:54: AAA/AUTHOR/TAC+: (787222339): user=admin
Feb 7 20:02:54: AAA/AUTHOR/TAC+: (787222339): send AV service=shell
Feb 7 20:02:54: AAA/AUTHOR/TAC+: (787222339): send AV cmd=show
Feb 7 20:02:54: AAA/AUTHOR/TAC+: (787222339): send AV cmd-arg=running-config
Feb 7 20:02:54: AAA/AUTHOR/TAC+: (787222339): send AV cmd-arg=<cr>
Feb 7 20:02:54: AAA/AUTHOR (787222339): Post authorization status = PASS_ADD
Feb 7 20:02:54: AAA/MEMORY: free_user (0xBA9C34) user='admin' ruser='ap' port='tty2' rem_addr='10.10.1.1' authen_type=ASCII service=NONE
priv=15 vrf= (id=0)
sbilgi Tue, 02/13/2007 - 12:22
These are event logs which show that these are just informational messages of sev 6.
Try removing the cache related commands and add the following commands,
aaa authen login default group < group name > local
and aaa authorization exec default group local
Vivek Santuka Wed, 02/14/2007 - 06:40
I really do not think that command authorization results will be cached. The cache keeps the user credentials and attributes passed during exec authorization but for command authorization it would have to check with the tacacs server always.
Vivek
khof Wed, 02/14/2007 - 07:13
Hi Vivek,
I have almost expected to see this answer. Then I have to go another way to finish this task.
Thanks.
Frank
