ASA5510/ ASA7.2(1) traffic denied that is allowed by acl
Answered Question
Feb 7th, 2007
I'm running ASA 7.2(1) on a 5510 and I'm receiving a deny on smtp:
Feb 07 2007 14:11:51: %ASA-4-106023: Deny tcp src eth1:100.100.252.107/25 dst eth0:200.29.52.3/40281 by access-group "acl-eth1"
The acl specifically allows this traffic, unless I'm misinterpreting the acl or the error. Can one of you see what the problem is?
Here are some statements from my config (sanitized):
interface Ethernet0/0
speed 100
duplex full
nameif eth0
security-level 0
ip address 200.29.52.1 255.255.255.0
interface Ethernet0/1
speed 100
duplex full
nameif eth1
security-level 90
ip address 192.129.254.7 255.255.255.0
access-list acl-eth1 extended permit tcp 100.100.252.0 255.255.255.0 host 200.29.52.3 eq smtp
access-list acl-eth0 extended permit tcp host 200.29.52.3 100.100.252.0 255.255.255.0 eq smtp
access-list matchall extended permit ip any any
nat (eth1) 0 access-list matchall
access-group acl-eth1 in interface eth1
access-group acl-eth0 in interface eth0
route eth1 0.0.0.0 0.0.0.0 192.129.254.2 1
Correct Answer by daviddtran about 9 years 7 months ago
are you using microsoft Exchange? Perhaps you
need to enter on the ASA:
no fixup protocol smtp 25
I recall running into similar problem like
yours with version 7.0(2) but with icmp.
I did the following and it fixed it:
no access-group acl-eth1 in int inside
maybe it will work in your case well. There
is a bug ID on this one.
Overall Rating: 5 (1 ratings)
acomiskey Wed, 02/07/2007 - 13:48
the log is showing a source port of 25, not a destination port
the acl to match that traffic would be
access-list acl-eth1 extended permit tcp 100.100.252.0 255.255.255.0 eq 25 host 200.29.52.3
What are you trying to accomplish?
calterio Wed, 02/07/2007 - 13:56
Yes, that is what I thought. We're converting from a PIX515 on 6.2(4) to the ASA5510s and the acls worked fine on the PIX, in that I did not see these deny messages. Mail (smtp) should be allowed between 200.29.52.3 and 100.100.252.0/24. I'm wondering if there's something I need to add to the 5510 config that was not needed in the PIX.
Correct Answer
daviddtran Wed, 02/07/2007 - 14:03
calterio Wed, 02/07/2007 - 14:16
No we're not using Exchange. I have another conversation going on right now related to the "no fixup". The ASA5510 with 7.2(1) won't take the command:
Ciscoasa(config)# no fixup protocol ftp 21
WARNING: 'no fixup ...' command not processed because no global policy-map is en
abled
No matching protocol-port pair found, fixup not removed
I'll try the access-group trick and post the results.
calterio Thu, 02/08/2007 - 06:38
Re-applying the access-group fixed the issue. Thank you, David! Can you point me to that Bug ID please?
daviddtran Thu, 02/08/2007 - 09:33
Hi calterio,
the Bug ID is CSCsd82114. I think I was the
first person to report this problem back in March 2006. But in my case, I was using ASDM
at the time when I noticed this issue. Funny
thing is that the bug ID stated that it should
have been fixed in your version as well. I
guess Cisco just doesn't know how to do QA
works.
Cisco Pix/ASA 7.x code is so buggy that it is
not even funny. We tried to migrate customers
from Checkpoint Firewalls (Checkpoint TAC
support sucks) to Cisco Pix firewalls (Cisco
TAC support good) but we've run into so many
issues with 7.x that it is not even funny.
What Cisco should do is start to hire
checkpoint programmers so that they can have
stable firewall code. But what do I know?
David
