IPCC Express estimated waiting time in queue
Answered Question
I have an ipcc express 4.0 and my customer wants the callers to hear a prompt saying the estimated waiting time in the queue.
Is that possible with this solution? maybe dealing with the scripts.
Any idea?
Jose
Correct Answer by lpezj about 9 years 7 months ago
Jose,
You can do the process that you like through the IPCC Express Scripts.
You have to use the 'Get Reporting Statistic' step under 'IPCC Express' in script editor and choose the statistic that you desire, in your case you have to select 'Report Object' -> 'CSQ IPCC Express' and afte, select 'Field' -> 'Expected Wait Time', stores that value in a variable a create as prompt to read the value.
Hope this helps,
Juan Luis
Overall Rating: 5 (5 ratings)
Correct Answer
lpezj Thu, 02/08/2007 - 00:19
Jose,
Hope this helps,
Juan Luis
mmelbourne Thu, 02/08/2007 - 11:33
The value returned is in seconds, so you may want to round it to a whole number of minutes, rather than play a potentially inaccurate number of seconds. (e.g. 2 minutes rather than 117 seconds).
Also, it is suggested that the estimated wait time (and position in queue) only be placed once when the call is first queued in case higher priority calls or RONA calls enter the queue and increase the wait time.
Please rate useful posts.
