network mgiration testing - cant ping between networks
Answered Question
Feb 7th, 2007
lab test config
wan_rtr (new)-10.10.150.1
wan_rtr )old)-172.16.0.1
problem:
wan_rtr(new) cant ping any vlans on 3750_new (it can ping 10.10.151.2)
wan_rtr(new) cant ping 3750_old, 2950(old)
wan_rtr(old) CAN ping 3750(old), 2959(old)
wan_rtr(old) can't ping any vlans on 3750_new
summary: can't ping between the two networks.
I'm sure this is simple routing issue but i'm missing it somewhere. thanks for any help.
Correct Answer by m-haddad about 9 years 7 months ago
You are missing some configuration:
2950 new:
ip default-gateway 10.10.151.1
3750 New:
ip routing
ip route 0.0.0.0 0.0.0.0 10.10.150.1
3750 Old:
ip default-gateway 172.16.0.11
2950 Old
WAN Router:
ip route 10.10.152.0 255.255.255.0 10.10.150.2
ip route 10.10.151.21 255.255.255.224 10.10.150.2
THe above should solve your connectivity issue,
Let me know how it goes and appreciate your rating,
Overall Rating: 5 (1 ratings)
Correct Answer
m-haddad Wed, 02/07/2007 - 16:28
2950 new:
3750 New:
ip routing
3750 Old:
2950 Old
WAN Router:
